Philco B572
Ok Started on this Philco..
[Image: http://i292.photobucket.com/albums/mm38/...enrkga.jpg]
I managed to get it apart not easy.. But found this...
[Image: http://i292.photobucket.com/albums/mm38/...aevsqq.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...0wjmzj.jpg]
Obviously not original...
But first problem.. How do you get this tube out? It has a shield that will not come off.. I tried twisting, pulling, prying ETC but will not budge.. Whats the Trick?
[Image: http://i292.photobucket.com/albums/mm38/...e26gev.jpg]
Skip...
Philco B572 - by vecher - 01-20-2017, 10:13 PM
RE: Philco B572 - by morzh - 01-20-2017, 10:45 PM
RE: Philco B572 - by Arran - 01-21-2017, 06:19 AM
RE: Philco B572 - by Radioroslyn - 01-21-2017, 08:41 AM
RE: Philco B572 - by OldRestorer - 01-21-2017, 11:01 AM
RE: Philco B572 - by vecher - 01-21-2017, 06:23 PM
RE: Philco B572 - by vecher - 01-25-2017, 06:02 PM
RE: Philco B572 - by vecher - 01-28-2017, 03:38 PM
RE: Philco B572 - by vecher - 01-29-2017, 12:29 AM
RE: Philco B572 - by klondike98 - 01-29-2017, 11:29 AM
RE: Philco B572 - by vecher - 01-31-2017, 11:17 AM
RE: Philco B572 - by klondike98 - 01-31-2017, 01:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6481 online users. [Complete List]
» 3 Member(s) | 6478 Guest(s)
