Philco model 87
Are you measuring the voltage on the 26 tube from filament pin to filament pin or from filament pin to chassis ground?
Across the two pins should be 1.5 V AC, but from either filament pin to ground there will be a DC voltage of around 5 to 10 V.
If you were referring to using the 100 V rated caps as the filament bypass, I don't think its a problem. There is only the bias voltage across the caps to ground, which is less than 10 Vdc.
Philco model 87 - by flatheadjr - 09-28-2016, 09:27 PM
RE: Philco model 87 - by flatheadjr - 01-11-2017, 09:24 PM
RE: Philco model 87 - by flatheadjr - 01-21-2017, 04:40 PM
RE: Philco model 87 - by Radioroslyn - 01-21-2017, 07:44 PM
RE: Philco model 87 - by Mondial - 01-21-2017, 09:34 PM
RE: Philco model 87 - by flatheadjr - 01-21-2017, 09:52 PM
RE: Philco model 87 - by Radioroslyn - 01-22-2017, 12:07 AM
RE: Philco model 87 - by flatheadjr - 01-22-2017, 12:30 AM
RE: Philco model 87 - by Radioroslyn - 01-22-2017, 07:10 AM
RE: Philco model 87 - by flatheadjr - 01-22-2017, 02:16 PM
RE: Philco model 87 - by Radioroslyn - 01-22-2017, 03:11 PM
RE: Philco model 87 - by flatheadjr - 01-22-2017, 03:48 PM
RE: Philco model 87 - by Radioroslyn - 01-23-2017, 01:25 AM
RE: Philco model 87 - by flatheadjr - 01-23-2017, 01:37 AM
RE: Philco model 87 - by Radioroslyn - 01-23-2017, 01:11 PM
RE: Philco model 77 - by Radioroslyn - 09-29-2016, 10:29 AM
RE: Philco model 77 - by flatheadjr - 09-29-2016, 12:17 PM
RE: Philco model 77 - by Arran - 10-01-2016, 05:00 AM
RE: Philco model 77 - by flatheadjr - 10-08-2016, 06:22 PM
RE: Philco model 77 - by Radioroslyn - 10-08-2016, 08:05 PM
RE: Philco model 77 - by flatheadjr - 10-12-2016, 09:31 PM
RE: Philco model 77 - by Radioroslyn - 10-12-2016, 10:35 PM
RE: Philco model 77 - by Radioroslyn - 10-17-2016, 08:05 PM
RE: Philco model 77 - by flatheadjr - 01-04-2017, 11:08 PM
RE: Philco model 77 - by Radioroslyn - 01-05-2017, 10:30 AM
RE: Philco model 77 - by flatheadjr - 01-05-2017, 09:46 PM
RE: Philco model 77 - by Arran - 01-09-2017, 04:02 AM
RE: Philco model 77 - by Radioroslyn - 01-09-2017, 11:42 AM
RE: Philco model 77 - by flatheadjr - 01-11-2017, 12:03 AM
RE: Philco model 77 - by Ron Ramirez - 01-11-2017, 01:20 PM
RE: Philco model 77 - by Radioroslyn - 01-11-2017, 09:03 AM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 8503 online users. [Complete List]
» 1 Member(s) | 8502 Guest(s)
