Magnetic Tuning Switch swap?
By failing in the "On" position do you mean that the shaft is seized or that it is free but the magnetic tuning will not turn off? If it is seized I would squirt some penetrating oil on the shaft bushing letting it soak for a while, and maybe apply a little heat too like from a soldering iron, and see if that frees it up.
 If it is really bad I would think about removing the switch and taking it apart to clean the hardened grease or rust out of it. Usually these have a "C" clip on the shaft just in front of the bushing which holds the shaft in place, if you remove that then you can get the shaft assembly out through the rear, that is if it's a normal rotary switch.
Magnetic Tuning Switch swap? - by k9uw - 01-21-2017, 05:01 PM
RE: Magnetic Tuning Switch swap? - by Radioroslyn - 01-21-2017, 07:46 PM
RE: Magnetic Tuning Switch swap? - by Arran - 01-22-2017, 04:28 AM
RE: Magnetic Tuning Switch swap? - by k9uw - 01-22-2017, 01:20 PM
RE: Magnetic Tuning Switch swap? - by klondike98 - 01-22-2017, 02:12 PM
RE: Magnetic Tuning Switch swap? - by Ron Ramirez - 01-22-2017, 04:54 PM
RE: Magnetic Tuning Switch swap? - by klondike98 - 01-23-2017, 11:26 AM
RE: Magnetic Tuning Switch swap? - by k9uw - 01-23-2017, 05:09 PM
RE: Magnetic Tuning Switch swap? - by Nick3092 - 01-24-2017, 09:07 PM
RE: Magnetic Tuning Switch swap? - by Phlogiston - 01-26-2017, 01:16 PM
RE: Magnetic Tuning Switch swap? - by k9uw - 02-01-2017, 11:47 PM
RE: Magnetic Tuning Switch swap? - by k9uw - 02-21-2017, 04:09 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 8550 online users. [Complete List]
» 1 Member(s) | 8549 Guest(s)
