Magnetic Tuning Switch swap?
The switch worked initially and produced a decisive "click" as it moved between positions.  Now, the shaft rotates a few degrees but it refuses to move into the "other" position.  I assume that it is stuck in the "on" position because the switch activates two dial lamps in the "on" position and those lamps are lit.  At least that is how I interpret the schematic, and that is how the switch functions on the 37-11.
Your suggestions for freeing the switch are appreciated.  I'll give those ideas a try and will report back, perhaps with photos as well.
Odd - the images of the schematic inserted into my original post do not show up for me when I view my own post.  When replying, however, they show up.  Anyone know why that would be?  I've tried 3 different browsers and the inserted images did not appear in any of them.
Mike, K9UW
Amherst, WI
Magnetic Tuning Switch swap? - by k9uw - 01-21-2017, 05:01 PM
RE: Magnetic Tuning Switch swap? - by Radioroslyn - 01-21-2017, 07:46 PM
RE: Magnetic Tuning Switch swap? - by Arran - 01-22-2017, 04:28 AM
RE: Magnetic Tuning Switch swap? - by k9uw - 01-22-2017, 01:20 PM
RE: Magnetic Tuning Switch swap? - by klondike98 - 01-22-2017, 02:12 PM
RE: Magnetic Tuning Switch swap? - by Ron Ramirez - 01-22-2017, 04:54 PM
RE: Magnetic Tuning Switch swap? - by klondike98 - 01-23-2017, 11:26 AM
RE: Magnetic Tuning Switch swap? - by k9uw - 01-23-2017, 05:09 PM
RE: Magnetic Tuning Switch swap? - by Nick3092 - 01-24-2017, 09:07 PM
RE: Magnetic Tuning Switch swap? - by Phlogiston - 01-26-2017, 01:16 PM
RE: Magnetic Tuning Switch swap? - by k9uw - 02-01-2017, 11:47 PM
RE: Magnetic Tuning Switch swap? - by k9uw - 02-21-2017, 04:09 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
