Reneamed: Winter Electronic restorations
#31
The Detrola 140 is DONE!
The hack job with the ballast tube has been undone and thanks to someone, It is fully restored electronically now!
It plays real well and I even got China on the Foreign band... Or at least they were talking in Chinese, Icon_lol
Cabinet will be a project and will have to wait till spring...
Winter Electronic restoration chronicles - by OldRestorer - 01-23-2017, 12:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
