Bendix 0526 AA5 Problem
Thanks Guys.
KCMike - Antenna is connected, Gang capacitor measures 3.4 meg to chassis (looks good).
Mondial - Yes, the osc coil is wired as the schematic. This is the "O" chassis (note P) and C5 is the one on the left. The C5 on the right is for "R" chassis and is a wire to B- on mine.
One more thing I left out, I checked the audio with a signal, 200 - 900 Hz, into the grid of the first audio stage and it was sweet music. It was C4 and R2 that I replaced. I'm going to see if I have another converter tube and try that.
Paul - Yes, this was a barn resident and the bakelite case looked the part. I used shoe polish after removing all the gunk and there are a few minor surface scratches at the corners otherwise it shines.
Bendix 0526 AA5 Problem - by RodB - 01-27-2017, 08:39 PM
RE: Bendix 0526 AA5 Problem - by KCMike - 01-27-2017, 10:24 PM
RE: Bendix 0526 AA5 Problem - by Mondial - 01-27-2017, 10:47 PM
RE: Bendix 0526 AA5 Problem - by Paul Philco322 - 01-27-2017, 10:52 PM
RE: Bendix 0526 AA5 Problem - by RodB - 01-27-2017, 11:44 PM
RE: Bendix 0526 AA5 Problem - by RodB - 01-27-2017, 11:56 PM
RE: Bendix 0526 AA5 Problem - by Mondial - 01-28-2017, 12:21 AM
RE: Bendix 0526 AA5 Problem - by RodB - 01-28-2017, 10:12 AM
RE: Bendix 0526 AA5 Problem - by Mondial - 01-28-2017, 03:31 PM
RE: Bendix 0526 AA5 Problem - by RodB - 01-28-2017, 04:53 PM
RE: Bendix 0526 AA5 Problem - by RodB - 01-28-2017, 09:34 PM
RE: Bendix 0526 AA5 Problem - by Paul Philco322 - 01-28-2017, 09:38 PM
RE: Bendix 0526 AA5 Problem - by RodB - 01-28-2017, 09:56 PM
RE: Bendix 0526 AA5 Problem - by Paul Philco322 - 01-30-2017, 09:40 PM
RE: Bendix 0526 AA5 Problem - by RodB - 02-21-2017, 04:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
