40-180: a newbie needs guidance
joeswl,
Thanks for the reply.
OK, so soldering not crimping. But can I just get any old wire and put it in (again, is something from RadioShack/Lowe's/HomeDepot ok,) or do I need to get some specialized wiring to replace the old?
I am pretty certain that the tubes in the sockets are the ones that were there when they left the factory. I don't think my wife's family members that owned the radio were the types to go fooling around with it. (but then again...) Luckily there are a few diagrams glued to the inside of the cabinet, so I think I can go off that as far as what's supposed to be where.
Thanks again.
Brian
40-180: a newbie needs guidance - by Guest - 12-11-2009, 03:59 PM
Re: 40-180: a newbie needs guidance - by Guest - 12-11-2009, 05:52 PM
Re: 40-180: a newbie needs guidance - by Guest - 12-12-2009, 10:00 PM
Re: 40-180: a newbie needs guidance - by DeckApe - 12-13-2009, 02:43 AM
Re: 40-180: a newbie needs guidance - by Raleigh - 12-26-2009, 09:30 PM
New member
Philco 630csx power cord
New member
There are currently 3215 online users. [Complete List]
» 5 Member(s) | 3210 Guest(s)
AvatarAvatarAvatarAvatar
