610 alignment
It doesn't matter, you could put the leads at the output transformer secondary, across the voice coil, also on AC, or measure DC on AVC voltage. They are all good indicators.
610 alignment - by keith49vj3 - 01-30-2017, 09:47 PM
RE: 610 alignment - by morzh - 01-30-2017, 09:50 PM
RE: 610 alignment - by keith49vj3 - 01-30-2017, 10:37 PM
RE: 610 alignment - by morzh - 01-30-2017, 10:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6245 online users. [Complete List]
» 4 Member(s) | 6241 Guest(s)
AvatarAvatarAvatarAvatar
