Philco 38-12 First restoration project!
Thanks for the advice guys. I'll pick up some of that steel wool tonight. The pumice free GoJo is a little trickier to find, however. Might have to order it online.
I forgot to mention that I also ordered the grill cloth in the picture below. That's not my radio, just the picture from the ebay listing.
I knew saying that I'm not completely restoring with original equipment would be a bit touchy, but I'll post some pics when its done. I think you guys will think its cool.
[Image: http://i.imgur.com/asCASDk.jpg]
RE: Philco 38-12 First restoration project! - by MuddyBoots - 01-31-2017, 01:13 PM
Philco 91 Tuning Condenser
There are currently 10177 online users. [Complete List]
» 2 Member(s) | 10175 Guest(s)
