Antenna Leads 116B
Impedance wise it's similar to the old flat tv ant wire more commonly know as 300 ohm twin lead.
http://rsgb.org/main/files/2012/10/Dipole_fig31.jpg
The feeder is the twin lead going vertical. the horizontal portion are the elements cut to the wavelength or a fraction of the wavelength. A full length ant for the bcb is abt 300 meters (abt 900') long. This just element (horizontal portion).
In practicality 60-100 works well as high up as you can get it.
Antenna Leads 116B - by jmac3ky - 01-31-2017, 04:05 PM
RE: Antenna Leads 116B - by jmac3ky - 01-31-2017, 05:30 PM
RE: Antenna Leads 116B - by Radioroslyn - 01-31-2017, 07:45 PM
RE: Antenna Leads 116B - by Ron Ramirez - 01-31-2017, 08:44 PM
RE: Antenna Leads 116B - by jmac3ky - 01-31-2017, 09:57 PM
RE: Antenna Leads 116B - by Ron Ramirez - 01-31-2017, 10:34 PM
RE: Antenna Leads 116B - by morzh - 01-31-2017, 11:21 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 7589 online users. [Complete List]
» 1 Member(s) | 7588 Guest(s)
