Kirk's Sterling deluxe
Well....I wanted to take the last shot at it. After all I did not change all tubes before, I just tested them.
Kirk's Sterling deluxe - by morzh - 12-31-2016, 08:51 PM
RE: Kirk's Sterling deluxe - by morzh - 12-31-2016, 10:09 PM
RE: Kirk's Sterling deluxe - by Radioroslyn - 12-31-2016, 11:52 PM
RE: Kirk's Sterling deluxe - by OldRestorer - 01-01-2017, 01:40 PM
RE: Kirk's Sterling deluxe - by morzh - 01-01-2017, 02:25 PM
RE: Kirk's Sterling deluxe - by Carl Travis - 01-01-2017, 04:42 PM
RE: Kirk's Sterling deluxe - by morzh - 01-01-2017, 05:26 PM
RE: Kirk's Sterling deluxe - by morzh - 01-02-2017, 06:05 PM
RE: Kirk's Sterling deluxe - by morzh - 01-15-2017, 10:35 PM
RE: Kirk's Sterling deluxe - by Arran - 01-16-2017, 06:01 AM
RE: Kirk's Sterling deluxe - by morzh - 01-16-2017, 10:12 AM
RE: Kirk's Sterling deluxe - by gregb - 01-16-2017, 11:51 AM
RE: Kirk's Sterling deluxe - by morzh - 01-16-2017, 12:58 PM
RE: Kirk's Sterling deluxe - by gregb - 01-16-2017, 05:50 PM
RE: Kirk's Sterling deluxe - by gregb - 01-16-2017, 09:24 PM
RE: Kirk's Sterling deluxe - by morzh - 01-16-2017, 10:39 PM
RE: Kirk's Sterling deluxe - by morzh - 01-16-2017, 10:55 PM
RE: Kirk's Sterling deluxe - by gregb - 01-16-2017, 11:22 PM
RE: Kirk's Sterling deluxe - by gregb - 01-17-2017, 12:15 AM
RE: Kirk's Sterling deluxe - by morzh - 01-17-2017, 09:07 AM
RE: Kirk's Sterling deluxe - by Arran - 01-19-2017, 07:04 AM
RE: Kirk's Sterling deluxe - by morzh - 01-19-2017, 08:59 AM
RE: Kirk's Sterling deluxe - by Arran - 01-21-2017, 06:12 AM
RE: Kirk's Sterling deluxe - by morzh - 01-21-2017, 12:36 PM
RE: Kirk's Sterling deluxe - by morzh - 02-01-2017, 11:26 PM
RE: Kirk's Sterling deluxe - by OldRestorer - 02-02-2017, 11:46 AM
RE: Kirk's Sterling deluxe - by morzh - 02-02-2017, 04:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6914 online users. [Complete List]
» 1 Member(s) | 6913 Guest(s)
