Zenith 5D610 dial cord diagram
Hello forum -
Anybody come across a dial cord routing diagram for a Zenith 5D610? I've looked in the usual places, Googled quite a bit, and still have not found anything. I am most interested in how many turns the cord wraps around the tuning shaft itself. Any clues?
Zenith 5D610 dial cord diagram - by mark123 - 02-03-2017, 03:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
