Radio Identification Help Needed Please
Bigdog, I've seen something like it, an Atwater-Kent. Can't be sure though. Maybe if you could provide the numbers printed on the tubes and total quantity of tubes, someone might be able to give more info. Joe
Joe
Re: Radio Identification Help Needed Please - by Joe Rossi - 01-13-2010, 11:54 PM
Philco 91 Tuning Condenser
There are currently 9822 online users. [Complete List]
» 1 Member(s) | 9821 Guest(s)
