Back to Philco 42-365
After more than a month I took my 42-365 out and tried once again to get it working. This is interesting. I set my signal generator to 1400 kc and touched the oscillator (XXL) grid and I get a station. Touching the antenna with the signal generator, same thing. I get a strong station. This is the only way that I get any reception. The lead from the generator has a 0.1 mfd capacitor attached to it. So I tried the same capacitor on an antenna wire and of course that doesn't work. Anyone know what's going on here?
Back to Philco 42-365 - by ccbaker13 - 02-05-2017, 04:48 PM
RE: Back to Philco 42-365 - by Radioroslyn - 02-05-2017, 05:24 PM
RE: Back to Philco 42-365 - by ccbaker13 - 02-05-2017, 05:50 PM
RE: Back to Philco 42-365 - by Ron Ramirez - 02-05-2017, 09:01 PM
RE: Back to Philco 42-365 - by ccbaker13 - 02-05-2017, 10:03 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6750 online users. [Complete List]
» 3 Member(s) | 6747 Guest(s)
