Back to Philco 42-365
Hmm...I picked this set up a couple of months ago and it has never worked. I've been through so much with it. I wonder if moisture is the case if it would be a long lasting effect? Would this be a situation where i could dry it out?
Back to Philco 42-365 - by ccbaker13 - 02-05-2017, 04:48 PM
RE: Back to Philco 42-365 - by Radioroslyn - 02-05-2017, 05:24 PM
RE: Back to Philco 42-365 - by ccbaker13 - 02-05-2017, 05:50 PM
RE: Back to Philco 42-365 - by Ron Ramirez - 02-05-2017, 09:01 PM
RE: Back to Philco 42-365 - by ccbaker13 - 02-05-2017, 10:03 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7422 online users. [Complete List]
» 3 Member(s) | 7419 Guest(s)
