Philco "Super 89" With 6A7 Tube
(02-06-2017, 05:49 PM)Ron Ramirez Wrote:  http://philcoradio.com/phorum/showthread.php?tid=14919
Thanks Ron! I couldn't find it anywhere.
I have experienced the same thing as Steve. I have done three of these now. Generally, I managed to get them to work with the 36 tube, but it is a real crapshoot. You can do all the steps, and it still maybe not work completely. The whole thing is real unpredictable.
Recently I posted that I made the switch to the 77 tube, and that did work well. I have another 89 sitting here to restore. If I have trouble with that one, I may go right to the 6A7 conversion.
I have couple spare coil forms so I would not have to destroy the original from the radio.
Mark K8KZ
Philco "Super 89" With 6A7 Tube - by markmokris - 02-06-2017, 05:24 PM
RE: Philco "Super 89" With 6A7 Tube - by markmokris - 02-07-2017, 12:12 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7567 online users. [Complete List]
» 3 Member(s) | 7564 Guest(s)
