Philco model 610
I have been away for a little and just getting back to this 610. I found out that the 6A7 did have problems and replaced it. It works from the 6a7 forward but I still have something wrong on the front end of this thing. The field coil and voice coil are good as well as the opt. It is like it doesn't have a load. The 80 tube is still showing 385 vdc on pins 1 and 4 and 785 vac across pins 2 and 3. By the way part 57 is perfect. I disconnected and re checked the transformer and the only thing that ohms a little high is the primary side. It was 7.2. Everything else is really close especially the secondary going to the 80 tube. I checked my connections in all areas leading up to my 6a7 tube just to make sure I didn't wire something wrong. I did have a thought. This may be a rookie question but when I was cleaning tar out of block number 32, I didn't realize until too late they were mica caps. If I bought the wrong replacements or wired these wrong would this cause the above problem. It is showing really high negative voltage at this block.
Philco model 610 - by Radio Hound - 01-17-2017, 08:14 PM
RE: Philco model 610 - by rck46 - 01-17-2017, 08:50 PM
RE: Philco model 610 - by Radioroslyn - 01-17-2017, 11:07 PM
RE: Philco model 610 - by Radio Hound - 01-18-2017, 08:01 PM
RE: Philco model 610 - by morzh - 01-18-2017, 08:16 PM
RE: Philco model 610 - by Radio Hound - 01-19-2017, 08:09 AM
RE: Philco model 610 - by Radioroslyn - 01-18-2017, 08:21 PM
RE: Philco model 610 - by Radio Hound - 01-19-2017, 08:13 AM
RE: Philco model 610 - by Radioroslyn - 01-19-2017, 08:25 AM
RE: Philco model 610 - by Radio Hound - 01-19-2017, 12:12 PM
RE: Philco model 610 - by morzh - 01-19-2017, 12:52 PM
RE: Philco model 610 - by Radio Hound - 01-19-2017, 01:09 PM
RE: Philco model 610 - by morzh - 01-19-2017, 02:31 PM
RE: Philco model 610 - by Mondial - 01-19-2017, 06:53 PM
RE: Philco model 610 - by Radio Hound - 01-20-2017, 11:45 AM
RE: Philco model 610 - by Radio Hound - 01-23-2017, 04:54 PM
RE: Philco model 610 - by morzh - 01-23-2017, 04:59 PM
RE: Philco model 610 - by Radio Hound - 01-23-2017, 05:02 PM
RE: Philco model 610 - by morzh - 01-23-2017, 05:03 PM
RE: Philco model 610 - by Radio Hound - 01-23-2017, 05:18 PM
RE: Philco model 610 - by morzh - 01-23-2017, 05:19 PM
RE: Philco model 610 - by Radio Hound - 01-23-2017, 05:24 PM
RE: Philco model 610 - by morzh - 01-23-2017, 05:35 PM
RE: Philco model 610 - by Radio Hound - 02-07-2017, 01:16 PM
RE: Philco model 610 - by morzh - 02-07-2017, 04:15 PM
RE: Philco model 610 - by Radio Hound - 02-07-2017, 04:50 PM
RE: Philco model 610 - by Radio Hound - 02-07-2017, 04:59 PM
RE: Philco model 610 - by morzh - 02-07-2017, 06:17 PM
RE: Philco model 610 - by keith49vj3 - 02-08-2017, 08:54 PM
RE: Philco model 610 - by Radioroslyn - 02-08-2017, 09:40 PM
RE: Philco model 610 - by keith49vj3 - 02-08-2017, 09:01 PM
RE: Philco model 610 - by keith49vj3 - 02-09-2017, 07:48 AM
RE: Philco model 610 - by klondike98 - 02-09-2017, 11:07 AM
RE: Philco model 610 - by TV MAN - 02-13-2017, 01:08 PM
RE: Philco model 610 - by Radio Hound - 02-13-2017, 06:04 PM
RE: Philco model 610 - by keith49vj3 - 02-13-2017, 09:13 PM
RE: Philco model 610 - by Radio Hound - 02-16-2017, 05:24 PM
RE: Philco model 610 - by keith49vj3 - 02-13-2017, 09:33 PM
RE: Philco model 610 - by keith49vj3 - 02-14-2017, 09:56 PM
RE: Philco model 610 - by keith49vj3 - 02-15-2017, 07:46 AM
RE: Philco model 610 - by keith49vj3 - 02-16-2017, 09:22 PM
RE: Philco model 610 - by morzh - 02-16-2017, 11:56 PM
RE: Philco model 610 - by keith49vj3 - 02-17-2017, 08:13 AM
RE: Philco model 610 - by morzh - 02-17-2017, 09:58 AM
RE: Philco model 610 - by keith49vj3 - 02-19-2017, 08:23 AM
RE: Philco model 610 - by morzh - 02-19-2017, 12:08 PM
RE: Philco model 610 - by Radio Hound - 02-20-2017, 08:35 PM
Users browsing this thread: 14 Guest(s)
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 7804 online users. [Complete List]
» 1 Member(s) | 7803 Guest(s)
