To make a 70 front panel or repair original ?
On a 70 does anyone know how the bottom of the radio was finished ? Bottom part where feet attach.  I have read many restoration articles but this was never mentioned.  Was it bare wood, stained, painted ?
Thks.
70 Bottom base finishing ? - by Silentphilco - 02-07-2017, 06:47 PM
Philco 91 Tuning Condenser
There are currently 9807 online users. [Complete List]
» 2 Member(s) | 9805 Guest(s)
