To make a 70 front panel or repair original ?
I can make a front panel in my wood shop that looks original or repair the one I have that would show some veneer lines where the new material is cut in on the wood grill.  There are quite a few areas that would be affected as I had to remake some of the curve sections that were broken.
Torn between keeping it original or making it look perfect.
70 Bottom base finishing ? - by Silentphilco - 02-07-2017, 06:47 PM
To make a 70 front panel or repair original ? - by Silentphilco - 02-07-2017, 06:57 PM
Philco 91 Tuning Condenser
There are currently 10017 online users. [Complete List]
» 1 Member(s) | 10016 Guest(s)
