westinghouse console wr370
Has anyone come across this console?  I have had it in my collection and have not touched it yet.
westinghouse console wr370 - by PhilcoJohn - 02-07-2017, 08:25 PM
RE: westinghouse console wr370 - by PhilcoJohn - 02-17-2017, 07:39 PM
RE: westinghouse console wr370 - by sam - 02-18-2017, 03:20 PM
RE: westinghouse console wr370 - by PhilcoJohn - 02-18-2017, 07:20 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
