Chinese frequency counter module
Hi..i am a new user here. As per my knowledge the counter has a MOSFET front end and a pair of back to back protection diodes from input to ground, so if the signal is more than 0.7 v peak the diodes will conduct and load the measured circuit. Better to add a series resistor to reduce signal if it is at high level as in a tube osc circuit.
pcb assembly services
Chinese frequency counter module - by Mondial - 12-01-2016, 05:42 PM
RE: Chinese frequency counter module - by Mondial - 12-01-2016, 10:09 PM
RE: Chinese frequency counter module - by Mondial - 12-02-2016, 09:27 AM
RE: Chinese frequency counter module - by Mondial - 12-20-2016, 09:38 PM
RE: Chinese frequency counter module - by JaseSerre - 02-09-2017, 11:50 AM
RE: Chinese frequency counter module - by Mondial - 02-09-2017, 04:40 PM
RE: Chinese frequency counter module - by Arran - 04-02-2017, 04:17 AM
RE: Chinese frequency counter module - by Mondial - 04-12-2017, 01:01 PM
RE: Chinese frequency counter module - by morzh - 11-30-2017, 03:54 PM
RE: Chinese frequency counter module - by govee - 01-25-2021, 04:03 PM
Eico 232 VTVM Schematic
There are currently 9029 online users. [Complete List]
» 1 Member(s) | 9028 Guest(s)
