Fisher 800B Restoration
Did the power up as and took reading on c-98 neg. to chassis. I get -15.1 volts. I had line voltage at 115v and it was drawing 2amps. Band set on FM. I tested all the tubes and the 2-12at7 tubes in MPX section were bad. Replaced them before the test.
The test speakers I had hooked up played clearly and balance control was smooth btwn left and right.
Should I replace anything else or just the parts recommended so far and then address the bias issue?
Thanks for helping on this.
Fisher 800B Restoration - by KCMike - 02-10-2017, 09:26 PM
RE: Fisher 800B Restoration - by Mondial - 02-11-2017, 12:19 AM
RE: Fisher 800B Restoration - by TV MAN - 02-11-2017, 10:48 AM
RE: Fisher 800B Restoration - by KCMike - 02-11-2017, 11:19 AM
RE: Fisher 800B Restoration - by Mondial - 02-11-2017, 12:05 PM
RE: Fisher 800B Restoration - by morzh - 02-11-2017, 12:29 PM
RE: Fisher 800B Restoration - by KCMike - 02-11-2017, 12:30 PM
RE: Fisher 800B Restoration - by Mondial - 02-11-2017, 12:43 PM
RE: Fisher 800B Restoration - by KCMike - 02-11-2017, 01:21 PM
RE: Fisher 800B Restoration - by Mondial - 02-11-2017, 01:29 PM
RE: Fisher 800B Restoration - by KCMike - 02-11-2017, 04:58 PM
RE: Fisher 800B Restoration - by Mondial - 02-11-2017, 05:49 PM
RE: Fisher 800B Restoration - by TV MAN - 02-12-2017, 03:34 PM
RE: Fisher 800B Restoration - by KCMike - 02-12-2017, 05:03 PM
RE: Fisher 800B Restoration - by Ron Ramirez - 02-12-2017, 05:31 PM
RE: Fisher 800B Restoration - by TV MAN - 02-12-2017, 09:14 PM
RE: Fisher 800B Restoration - by Ron Ramirez - 02-12-2017, 10:54 PM
RE: Fisher 800B Restoration - by KCMike - 02-12-2017, 11:02 PM
RE: Fisher 800B Restoration - by sam - 02-13-2017, 01:10 PM
RE: Fisher 800B Restoration - by Ron Ramirez - 02-13-2017, 01:27 PM
RE: Fisher 800B Restoration - by TV MAN - 02-13-2017, 01:29 PM
RE: Fisher 800B Restoration - by KCMike - 02-18-2017, 10:11 PM
RE: Fisher 800B Restoration - by Mondial - 02-19-2017, 09:26 AM
RE: Fisher 800B Restoration - by KCMike - 02-19-2017, 07:52 PM
RE: Fisher 800B Restoration - by Mondial - 02-19-2017, 08:34 PM
RE: Fisher 800B Restoration - by KCMike - 02-19-2017, 08:46 PM
RE: Fisher 800B Restoration - by KCMike - 02-21-2017, 11:04 PM
RE: Fisher 800B Restoration - by Mondial - 02-22-2017, 10:05 AM
RE: Fisher 800B Restoration - by TV MAN - 02-22-2017, 12:49 PM
RE: Fisher 800B Restoration - by KCMike - 02-23-2017, 05:36 PM
RE: Fisher 800B Restoration - by KCMike - 02-28-2017, 05:08 PM
RE: Fisher 800B Restoration - by KCMike - 03-02-2017, 11:35 PM
RE: Fisher 800B Restoration - by Clayvu - 04-12-2019, 10:36 PM
Eico 232 VTVM Schematic
There are currently 4488 online users. [Complete List]
» 2 Member(s) | 4486 Guest(s)
