SW on Philco 60B
(02-11-2017, 03:31 PM)tiloco Wrote:
(02-11-2017, 02:42 PM)Jim Koehler Wrote:  Try another oscillator tube for starters. What kind of antenna are you using?
Thanks Jim, I will try another tube. I have about 45' of wire as an antenna, but it goes around the perimeter of the room, up and down a hallway about 16' above ground.
Alas, well I tried two different 6A7s and neither seemed to make much of a difference. SW still very weak. Could I have screwed something up when aligning the set? I would think that with the fixed cap for LF that there is not much one can do about the SW band on this set. Should I replace the 2100pF with the 1400pF the schematic calls for, or is that just chasing my tail?
SW on Philco 60B - by tiloco - 02-11-2017, 09:40 AM
RE: SW on Philco 60B - by Jim Koehler - 02-11-2017, 02:42 PM
RE: SW on Philco 60B - by tiloco - 02-11-2017, 03:31 PM
RE: SW on Philco 60B - by tiloco - 02-11-2017, 09:04 PM
RE: SW on Philco 60B - by Radioroslyn - 02-11-2017, 09:17 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 8513 online users. [Complete List]
» 1 Member(s) | 8512 Guest(s)
