replacing filter caps in 37-610
I am relatively new to doing some of this electronic restoration, although I've done much of this sort of thing outside of radios in the past.  My question is, on my 37-610, I have done a cap job but am divided on what to do about the filter caps.  On this chassis there is a single bakelite housing that has the 2 .02uf filter caps inside.  There are 3 separate connection points on the underside and was just wondering how you would go about replacing these.  I have a pair of ceramics to replace with, but it doesn't seem that the original housing is reusable, so, with the 3 connections on the old setup, would the center connection be the common and the 2 outer ones be positive or? The schematic that I have is a bit fuzzy so I'm just wondering what some Philco veterans have done with these. Thanks!
replacing filter caps in 37-610 - by conceptchris - 02-13-2017, 11:39 AM
RE: replacing filter caps in 37-610 - by Mondial - 02-13-2017, 12:42 PM
RE: replacing filter caps in 37-610 - by morzh - 02-13-2017, 12:50 PM
RE: replacing filter caps in 37-610 - by ohiobill - 03-05-2017, 03:44 PM
RE: replacing filter caps in 37-610 - by ohiobill - 03-05-2017, 05:29 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4315 online users. [Complete List]
» 3 Member(s) | 4312 Guest(s)
