Painted 42-PT91
Ya never know how it wound up like that, maybe  a kid had it and was trying to redo it. The drips marks are rough though.
I repainted some radiator covers for my home and used some Rustoleum in a can. I avoided the drips, many coats and thin coats to avoid putting on enough to run.
I bet you get it to look nice.
Painted 42-PT91 - by dal61 - 02-14-2017, 11:32 PM
RE: Painted 42-PT91 - by Arran - 02-15-2017, 02:18 AM
RE: Painted 42-PT91 - by OldRestorer - 02-15-2017, 08:22 AM
RE: Painted 42-PT91 - by dal61 - 02-15-2017, 08:31 AM
RE: Painted 42-PT91 - by dal61 - 02-15-2017, 03:19 PM
RE: Painted 42-PT91 - by wb6jhj - 02-15-2017, 06:50 PM
RE: Painted 42-PT91 - by dal61 - 02-15-2017, 11:30 PM
RE: Painted 42-PT91 - by klondike98 - 02-15-2017, 09:49 PM
RE: Painted 42-PT91 - by OldRestorer - 02-16-2017, 04:06 PM
RE: Painted 42-PT91 - by dal61 - 02-16-2017, 06:45 PM
RE: Painted 42-PT91 - by Arran - 02-16-2017, 08:05 PM
RE: Painted 42-PT91 - by dal61 - 02-16-2017, 09:30 PM
RE: Painted 42-PT91 - by Paul Philco322 - 02-16-2017, 10:29 PM
RE: Painted 42-PT91 - by dal61 - 02-20-2017, 01:12 PM
RE: Painted 42-PT91 - by dal61 - 02-20-2017, 03:36 PM
RE: Painted 42-PT91 - by Arran - 02-21-2017, 04:59 AM
Philco 91 Tuning Condenser
There are currently 6893 online users. [Complete List]
» 2 Member(s) | 6891 Guest(s)
