Philco 20 - variable capacitor tuning
Hi, i was researching threads and Ron mentioned an enhanced schematic of the Philco 20 with '+/- ' in the filter condenser block etc.  I would appreciate this more detailed schematic but I can't find it,  the links are gone.  Can someone help me with this schematic? thanks in advance.  I remember using a nice Model 90 schematic (the numbers weren't "blurred") from here that helped me a lot. Rich
Philco Model 20 schematic by Ron? - by winston763 - 02-19-2017, 01:56 AM
RE: Philco Model 20 schematic by Ron? - by sam - 02-20-2017, 12:21 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4886 online users. [Complete List]
» 2 Member(s) | 4884 Guest(s)
