Painted 42-PT91
Started stripping process on Saturday. Tried the Pine-sol soak until last evening.  Loosened some of the newer spray paint.  Scraped all I could and let it soak until this morning.   Got up and started in again this morning (day off, today!)...about 3/4 of the paint scraped off pretty easy....down to bakelite.  The grill and tough spots have been being soaked/scraped with some old stripper I had in the garage...I've been working a couple hours and it is about 90% stripped. Still working on grill area....still not sure if I will be able to polish up or paint, but it is a bunch of work.  I do enjoy it, though.   I should have taken a few pics through the process, but didn't think about it.   When I head back out to scrape, I'll snap one.
Painted 42-PT91 - by dal61 - 02-14-2017, 11:32 PM
RE: Painted 42-PT91 - by Arran - 02-15-2017, 02:18 AM
RE: Painted 42-PT91 - by OldRestorer - 02-15-2017, 08:22 AM
RE: Painted 42-PT91 - by dal61 - 02-15-2017, 08:31 AM
RE: Painted 42-PT91 - by dal61 - 02-15-2017, 03:19 PM
RE: Painted 42-PT91 - by wb6jhj - 02-15-2017, 06:50 PM
RE: Painted 42-PT91 - by dal61 - 02-15-2017, 11:30 PM
RE: Painted 42-PT91 - by klondike98 - 02-15-2017, 09:49 PM
RE: Painted 42-PT91 - by OldRestorer - 02-16-2017, 04:06 PM
RE: Painted 42-PT91 - by dal61 - 02-16-2017, 06:45 PM
RE: Painted 42-PT91 - by Arran - 02-16-2017, 08:05 PM
RE: Painted 42-PT91 - by dal61 - 02-16-2017, 09:30 PM
RE: Painted 42-PT91 - by Paul Philco322 - 02-16-2017, 10:29 PM
RE: Painted 42-PT91 - by dal61 - 02-20-2017, 01:12 PM
RE: Painted 42-PT91 - by dal61 - 02-20-2017, 03:36 PM
RE: Painted 42-PT91 - by Arran - 02-21-2017, 04:59 AM
