Philco Model 37-620
jack I added pic to your post
I hate using photo bucket any more Icon_thumbdown Icon_thumbdown
sam
Philco Model 37-620 - by Mhz-Radio - 02-20-2017, 02:08 PM
RE: Philco Model 37-620 - by sam - 02-20-2017, 05:36 PM
RE: Philco Model 37-620 - by Mhz-Radio - 02-20-2017, 05:49 PM
RE: Philco Model 37-620 - by sam - 02-20-2017, 07:00 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6253 online users. [Complete List]
» 4 Member(s) | 6249 Guest(s)
AvatarAvatarAvatarAvatar
