Crosley 66TC bad Transformer.
Hi Doc,
You can figure about 7ma each for all the 6v tubes except for the 6F6 it's going to use about 20ma on the HV winding.
So total your looking at 50ma. or better. Other calculations look good.
Don't know what your situation is but I'd buy a few parts chassis for a few dollars rather that a new transformer. But I'm cheap.
Crosley 66TC bad Transformer. - by Eric - 02-22-2017, 01:19 PM
RE: Crosley 66TC bad Transformer. - by Radioroslyn - 02-22-2017, 04:33 PM
RE: Crosley 66TC bad Transformer. - by Eric - 02-22-2017, 06:17 PM
RE: Crosley 66TC bad Transformer. - by Eric - 02-22-2017, 07:48 PM
RE: Crosley 66TC bad Transformer. - by Eric - 02-23-2017, 11:15 AM
RE: Crosley 66TC bad Transformer. - by Eric - 03-05-2017, 04:07 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
