An Original Philco Hippo
I just bought this Philco Hippo for $20.00..
 I have recapped it  and everything under the chassis was original, and it has the original back.
   I cleaned the cabinet with a degreaser, then used the old brasso on it .. I gave it a coat of Renaissance
wax. and it's done. It is the best hippo I have SEEN.
  I would like to know  what wattages of bulb should be in the radio? .. I don't want it to get too hot under there.
  Thanks  Dan in Calgary .
  I can't wait for spring to get here as I have 10 cabinets to get stripped  and refinished.
   Living in Calgary Alberta
An Original Philco Hippo - by Dan Walker - 02-23-2017, 09:13 AM
RE: An Original Philco Hippo - by David - 02-23-2017, 09:38 AM
RE: An Original Philco Hippo - by morzh - 02-23-2017, 09:39 AM
RE: An Original Philco Hippo - by Dan Walker - 02-23-2017, 03:43 PM
RE: An Original Philco Hippo - by morzh - 02-23-2017, 05:37 PM
RE: An Original Philco Hippo - by Paul Philco322 - 02-23-2017, 09:38 PM
RE: An Original Philco Hippo - by Dan Walker - 02-23-2017, 11:31 PM
RE: An Original Philco Hippo - by Arran - 02-24-2017, 01:32 AM
RE: An Original Philco Hippo - by Dan Walker - 02-24-2017, 12:00 PM
RE: An Original Philco Hippo - by Dan Walker - 02-24-2017, 02:08 PM
RE: An Original Philco Hippo - by David - 02-24-2017, 08:43 PM
RE: An Original Philco Hippo - by Dan Walker - 02-24-2017, 09:51 PM
RE: An Original Philco Hippo - by Paul Philco322 - 02-24-2017, 10:52 PM
RE: An Original Philco Hippo - by morzh - 02-24-2017, 11:42 PM
RE: An Original Philco Hippo - by Arran - 02-24-2017, 11:50 PM
RE: An Original Philco Hippo - by David - 02-26-2017, 08:40 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
