Seeking advices on eliminating noise on a Philco 70-A
Hi Paul,
Thanks for the sound advises.
I have changed the 24's around with the same results.
I will acquire some new 24's and will see the impact on this receiver.
As you recommanded, degraded solder connections could be the cause.
My next step will be to resolder all the joints and clean the tube sockets.
A lenghty but mandatory troubleshooting process.
Cheers
Daniel
Noise in the 70 detector - by AI2V - 01-13-2006, 12:40 PM
[No subject] - by Guest - 01-13-2006, 03:08 PM
[No subject] - by PTurney - 01-13-2006, 07:20 PM
[No subject] - by Guest - 01-14-2006, 09:41 AM
[No subject] - by Guest - 01-24-2006, 05:53 PM
