Philco model 610 rebuild - by Tim P.
#31
(03-18-2014, 02:41 PM)Chuck Schwark Wrote:  Those 110 pF caps are wax-paper-foil.
Use replacement 110pF silver-micas.
#6 on page 1. They sure look like micas, but I noted in the parts list some say "mica", and others don't. Now that I look, #43 does say it's a mica (it also seems to depend on which part list I look at!). Dunno Oh well, I didn't like the way it was soldered in there, so it is replaced. Probably wont hurt anything anyway for an 80 year part. Thanks for the link to find those washers. Gonna tackle #45 next.
Tim
Philco model 610 rebuild - by Tim P. - by TV MAN - 03-16-2014, 04:12 PM
RE: Philco model 610 rebuild - by Tim P. - by TV MAN - 02-25-2017, 12:12 AM
Users browsing this thread: 29 Guest(s)
The speaker table error?
Philco 70 antenna lead
