Help identifying a Wells Gardner console
Greg,
Nice radio in the pics she sent me. With paying someone to pack it, along with the high $300 price tag, makes it really pricey. Thanks for the lead. It was worth checking into.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
