48-200 code 121 schematic?
Hello, I just checked the riders manual I have on my computer and it mentions the code121 and states
"Code 121 of the three models is identical to code 125 with the following exceptions." It then mentions the tube difference you already know about. So I think you can use the measurements of code 125.
Where is the .05 capacitor you have in the circuit?
48-200 code 121 schematic? - by sdradioman - 02-25-2017, 11:02 AM
RE: 48-200 code 121 schematic? - by KCMike - 02-25-2017, 12:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8514 online users. [Complete List]
» 3 Member(s) | 8511 Guest(s)
