Zenith 5D011 Consoltone
Ok, Since no answers.. I put together 2 .1 600 Volt caps in series to make a .05 at 1200 Volts and put in ..
Finished wiring up the E-Caps and tomorrow will power it up..
Skip..
Zenith 5D011 Consoltone - by vecher - 02-19-2017, 08:25 PM
RE: Zenith 5D011 Consoltone - by vecher - 02-20-2017, 03:02 PM
RE: Zenith 5D011 Consoltone - by Paul Philco322 - 02-20-2017, 08:52 PM
RE: Zenith 5D011 Consoltone - by vecher - 02-26-2017, 10:09 PM
RE: Zenith 5D011 Consoltone - by vecher - 02-28-2017, 12:23 AM
RE: Zenith 5D011 Consoltone - by morzh - 02-28-2017, 09:11 AM
RE: Zenith 5D011 Consoltone - by Mondial - 02-28-2017, 01:34 PM
RE: Zenith 5D011 Consoltone - by vecher - 02-28-2017, 08:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
