Zenith 5D011 Consoltone
You might want a high voltage cap in that location. It connects between the chassis and AC line.
Depending on which way the line cord is plugged in, its either neutral or hot connected to the chassis if the cap shorts.
Zenith 5D011 Consoltone - by vecher - 02-19-2017, 08:25 PM
RE: Zenith 5D011 Consoltone - by vecher - 02-20-2017, 03:02 PM
RE: Zenith 5D011 Consoltone - by Paul Philco322 - 02-20-2017, 08:52 PM
RE: Zenith 5D011 Consoltone - by vecher - 02-26-2017, 10:09 PM
RE: Zenith 5D011 Consoltone - by vecher - 02-28-2017, 12:23 AM
RE: Zenith 5D011 Consoltone - by morzh - 02-28-2017, 09:11 AM
RE: Zenith 5D011 Consoltone - by Mondial - 02-28-2017, 01:34 PM
RE: Zenith 5D011 Consoltone - by vecher - 02-28-2017, 08:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
