what to do next
#40
Great! I'm glad to help get it working and share a little experiences I had over the years. We all had to start somewhere with someone who we willing teach us newbies a thing or two. I was lucky as it was my dad.
Hummmmm ? Well I'd try hooking an 20 to 40mfd @ 450V electrolytic cap from points C (going to the + side of the cap) and point D (going to the - side of the cap). Also having a good ground may help. A little bit of hum would be normal.
On your rf amp tube may just need to clean the socket. My model 70 chairside had a similar problem with the 27 the in the oscillator. It would play for a while then die. The filament would go out.
I was wondering if it had local/distance switch. The printed diagram I was using is kinda small. Now that you mention it I see it on the primary of the first if transformer. Haven't seen many Philcos with a L/D switch.
what to do next - by denver - 01-15-2010, 04:22 PM
Re: what to do next - by Carl Travis - 01-15-2010, 04:50 PM
Re: what to do next - by denver - 01-15-2010, 07:06 PM
Re: what to do next - by 7estatdef - 01-15-2010, 07:23 PM
Re: what to do next - by denver - 01-15-2010, 08:24 PM
Re: what to do next - by denver - 01-16-2010, 12:40 PM
Re: what to do next - by 7estatdef - 01-16-2010, 02:39 PM
Re: what to do next - by denver - 01-16-2010, 02:56 PM
Re: what to do next - by 7estatdef - 01-16-2010, 03:00 PM
Re: what to do next - by 7estatdef - 01-16-2010, 03:06 PM
Re: what to do next - by denver - 01-16-2010, 03:34 PM
Re: what to do next - by denver - 01-16-2010, 04:20 PM
Re: what to do next - by 7estatdef - 01-16-2010, 07:27 PM
Re: what to do next - by denver - 01-16-2010, 07:48 PM
Re: what to do next - by 7estatdef - 01-16-2010, 07:50 PM
Re: what to do next - by 7estatdef - 01-16-2010, 08:04 PM
Re: what to do next - by denver - 01-16-2010, 11:22 PM
Re: what to do next - by denver - 01-16-2010, 11:30 PM
Re: what to do next - by 7estatdef - 01-17-2010, 08:47 AM
Re: what to do next - by denver - 01-18-2010, 10:41 AM
Re: what to do next - by 7estatdef - 01-18-2010, 01:39 PM
Re: what to do next - by denver - 01-18-2010, 03:26 PM
Re: what to do next - by denver - 01-18-2010, 04:31 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:01 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:33 PM
Re: what to do next - by denver - 01-18-2010, 06:42 PM
Re: what to do next - by 7estatdef - 01-18-2010, 06:58 PM
Re: what to do next - by denver - 01-18-2010, 07:17 PM
Re: what to do next - by 7estatdef - 01-18-2010, 08:59 PM
Re: what to do next - by denver - 01-18-2010, 10:44 PM
Re: what to do next - by 7estatdef - 01-19-2010, 08:18 AM
Re: what to do next - by denver - 01-19-2010, 11:26 AM
Re: what to do next - by 7estatdef - 01-19-2010, 06:34 PM
Re: what to do next - by denver - 01-19-2010, 09:51 PM
Re: what to do next - by denver - 01-20-2010, 04:43 PM
Re: what to do next - by 7estatdef - 01-20-2010, 08:57 PM
Re: what to do next - by denver - 01-20-2010, 09:20 PM
Re: what to do next - by 7estatdef - 01-20-2010, 10:16 PM
Re: what to do next - by denver - 01-21-2010, 01:59 PM
Re: what to do next - by 7estatdef - 01-21-2010, 06:21 PM
Re: what to do next - by denver - 01-21-2010, 07:46 PM
Re: what to do next - by 7estatdef - 01-30-2010, 08:40 AM
Re: what to do next - by denver - 01-30-2010, 04:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
