First Wurlitzer?
C-3 form around 1924. Video of radio in operation:
http://www.russoldradios.com/blog
First Wurlitzer? - by Phlogiston - 03-02-2017, 05:56 PM
RE: First Wurlitzer? - by KCMike - 03-02-2017, 09:00 PM
RE: First Wurlitzer? - by Phlogiston - 03-05-2017, 01:21 PM
RE: First Wurlitzer? - by Ron Ramirez - 03-06-2017, 10:57 PM
RE: First Wurlitzer? - by Eliot Ness - 03-03-2017, 05:17 PM
RE: First Wurlitzer? - by Phlogiston - 03-05-2017, 01:14 PM
RE: First Wurlitzer? - by Arran - 03-06-2017, 05:26 AM
RE: First Wurlitzer? - by Phlogiston - 03-06-2017, 04:28 PM
RE: First Wurlitzer? - by Phlogiston - 03-07-2017, 11:56 AM
RE: First Wurlitzer? - by Kenneth F. Besso Jr. - 03-07-2017, 08:01 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
