How do I use an ultrasonic parts cleaner?
I just received an ultrasonic parts cleaner big enough to clean a tuner or carburetor. I have the manual that tells me a whole lota nothing. Icon_mad I would like to clean a tuner and I don't know if I should use tap water, distilled water, dish soap or what, and how long to run a cycle. Ok, it is a 40khz 180w, heated, 6.5L. It has a timer and temp control. I am sure there are some that have already used these for cleaning tuners and such. Any tips on using would be greatly appreciated.
Tim
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8669 online users. [Complete List]
» 3 Member(s) | 8666 Guest(s)
