Philco PT-4
Well, Powered up.. At 117 Volts I get .21 Amps.. Stations load and clear across band.. I do not think alignment is required.. Plays great as is.. Only left to do is Cabinet a little more and put back in...
Thanks to all for responses. On to next.. Not sure what one to do.
Skip...
Philco PT-4 - by vecher - 03-03-2017, 01:08 AM
RE: Philco PT-4 - by morzh - 03-03-2017, 09:45 AM
RE: Philco PT-4 - by Jim Koehler - 03-03-2017, 10:25 AM
RE: Philco PT-4 - by Arran - 03-05-2017, 12:10 AM
RE: Philco PT-4 - by Paul Philco322 - 03-03-2017, 09:07 PM
RE: Philco PT-4 - by vecher - 03-04-2017, 04:55 PM
RE: Philco PT-4 - by vecher - 03-07-2017, 10:09 PM
RE: Philco PT-4 - by Mondial - 03-07-2017, 10:33 PM
RE: Philco PT-4 - by morzh - 03-07-2017, 10:51 PM
RE: Philco PT-4 - by vecher - 03-08-2017, 12:15 AM
RE: Philco PT-4 - by vecher - 03-08-2017, 07:47 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4063 online users. [Complete List]
» 3 Member(s) | 4060 Guest(s)
