Philco 38-4 My first try at radio restoration
Will I think the first thing to do is pull the 5Y4 and measure between pins 3 and 5 you should have about 600v ac. If you do then your power transformer more than likely OK. If not you will be looking for a power transformer. What you will need to replace it is 120v primary Secondaries HV 600 to 650vac ct @ 90ma 6.3vac @3a 5v@2a. That will give you 250-300vdc.
Philco 38-4 My first try at radio restoration - by Guest - 12-17-2009, 01:29 AM
Re: Philco 38-4 My first try at radio restoration - by 7estatdef - 12-25-2009, 11:17 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1535 online users. [Complete List]
» 1 Member(s) | 1534 Guest(s)
