Canadian Philco model 20
I just bought this Philco  model 20.   Everything seems to be there.
  Is there anything particular I should know about this radio, before I get into replacing the caps?
 Dan in Calgary.
   Living in Calgary Alberta
Canadian Philco model 20 - by Dan Walker - 03-13-2017, 02:22 PM
RE: Canadian Philco nidel 20 - by gregb - 03-13-2017, 03:25 PM
RE: Canadian Philco nidel 20 - by Steve Davis - 03-13-2017, 03:50 PM
RE: Canadian Philco nidel 20 - by Radioroslyn - 03-13-2017, 04:05 PM
RE: Canadian Philco nidel 20 - by Radioroslyn - 03-13-2017, 03:52 PM
RE: Canadian Philco nidel 20 - by morzh - 03-13-2017, 04:13 PM
RE: Canadian Philco nidel 20 - by Steve Davis - 03-13-2017, 04:40 PM
RE: Canadian Philco model 20 - by morzh - 03-13-2017, 04:53 PM
RE: Canadian Philco model 20 - by Mondial - 03-13-2017, 09:26 PM
RE: Canadian Philco model 20 - by gregb - 03-13-2017, 10:17 PM
RE: Canadian Philco model 20 - by Arran - 03-13-2017, 11:12 PM
RE: Canadian Philco model 20 - by morzh - 03-14-2017, 09:26 AM
RE: Canadian Philco model 20 - by Arran - 03-14-2017, 07:43 PM
RE: Canadian Philco model 20 - by 462ron - 03-14-2017, 05:12 PM
RE: Canadian Philco model 20 - by morzh - 03-14-2017, 07:55 PM
RE: Canadian Philco model 20 - by Steve Davis - 03-14-2017, 08:54 PM
RE: Canadian Philco model 20 - by morzh - 03-14-2017, 09:17 PM
RE: Canadian Philco model 20 - by Steve Davis - 03-14-2017, 10:52 PM
RE: Canadian Philco model 20 - by morzh - 03-14-2017, 10:58 PM
RE: Canadian Philco model 20 - by Dan Walker - 03-16-2017, 05:28 PM
RE: Canadian Philco model 20 - by morzh - 03-16-2017, 10:10 PM
RE: Canadian Philco model 20 - by Dan Walker - 03-16-2017, 10:25 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6589 online users. [Complete List]
» 3 Member(s) | 6586 Guest(s)
