philco 47-1230 strange Cap
I am in the process of restoring this model and came across a strange cap in the fm section. it is a .01 mfd cap with 3 leads and i was wondering how do i duplicate this cap. here is a picture of the cap and any help with this would be appreiciated.
[Image: http://i1281.photobucket.com/albums/a508...wuz8go.jpg]
philco 47-1230 strange Cap - by Ronin61 - 03-13-2017, 03:03 PM
RE: philco 47-1230 strange Cap - by Ron Ramirez - 03-13-2017, 03:43 PM
RE: philco 47-1230 strange Cap - by Ronin61 - 03-13-2017, 05:51 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8513 online users. [Complete List]
» 3 Member(s) | 8510 Guest(s)
