Guard needed for Philco Dynamic Reproducer !
Can anyone help me locate the "forked guard " figure 5, 6, and 7 in my Photo Bucket attachment or the "new-type" guard in figure # 8 that are used with the new style Philco offset-type needle, figure # 4 ? Even the entire tone arm for the Philco Dynamic reproducer would sure come in handy ! The tone arm originally had the "nearly straight shanked needle with no guards and the only needle I was able to locate was the newer style offset-type needle that needs the guards !
Thanks for your help , Lee Petrie
[Image: http://i404.photobucket.com/albums/pp122...266102.jpg]
Guard needed for Philco Dynamic Reproducer ! - by Lee Petrie - 12-26-2009, 08:56 PM
