03-13-2017, 04:05 PM
(03-13-2017, 03:50 PM)Steve Davis Wrote:Quote:Don't use electrolytic's in the filter can, use 630 volt poly caps.
I have read this many times but, I don't understand why. When I look at the 20 schematic, I see the power supply is virtually identical to the one used in a 70 or a 90 or just about any of the other Philco models. So why are electrolytic capacitors OK in a 70 or a 90 but not in a 20?
There is one big difference if you look at the values of the caps the 20 uses much smaller capacitance. Electrolytic caps in these small values don't hold up well. I replaced the caps in my 87 which uses these small values w/ 4.7mf@ 450v (two in series to give me about 2.3mf @900v). Lasted about 4 month and the input cap shorted! Since then I've been using polys and haven't had a problem. Methinks it has something to do with something called ripple current.
