philco 47-1230 strange Cap
Thank you Ron for the quick reply and solution.
philco 47-1230 strange Cap - by Ronin61 - 03-13-2017, 03:03 PM
RE: philco 47-1230 strange Cap - by Ron Ramirez - 03-13-2017, 03:43 PM
RE: philco 47-1230 strange Cap - by Ronin61 - 03-13-2017, 05:51 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6369 online users. [Complete List]
» 3 Member(s) | 6366 Guest(s)
