35A5 tube substitution
The voltage readings you are getting are exactly in line with what would be expected with the 50A5 installed.
If you add up the rated filament voltages of all the tubes you have now in the circuit, it comes to 135 V. Since you are actually only applying about 120 V, each tube will receive a bit less than its rated voltage, which is what you are measuring.
When you install the proper 35A5, all the filament voltages should be at or near their rated values.
35A5 tube substitution - by wally73 - 03-13-2017, 10:47 AM
RE: 35A5 tube substitution - by sam - 03-13-2017, 11:57 AM
RE: 35A5 tube substitution - by David - 03-13-2017, 12:11 PM
RE: 35A5 tube substitution - by TV MAN - 03-13-2017, 12:37 PM
RE: 35A5 tube substitution - by Radioroslyn - 03-13-2017, 02:59 PM
RE: 35A5 tube substitution - by wally73 - 03-13-2017, 04:54 PM
RE: 35A5 tube substitution - by wally73 - 03-13-2017, 04:57 PM
RE: 35A5 tube substitution - by Arran - 03-13-2017, 11:43 PM
RE: 35A5 tube substitution - by wally73 - 03-14-2017, 04:18 PM
RE: 35A5 tube substitution - by wally73 - 03-15-2017, 08:36 AM
RE: 35A5 tube substitution - by Mondial - 03-15-2017, 09:13 AM
RE: 35A5 tube substitution - by wally73 - 03-15-2017, 10:05 AM
RE: 35A5 tube substitution - by Mondial - 03-15-2017, 11:29 AM
RE: 35A5 tube substitution - by wally73 - 03-15-2017, 11:45 AM
RE: 35A5 tube substitution - by Radioroslyn - 03-15-2017, 02:03 PM
RE: 35A5 tube substitution - by wally73 - 03-15-2017, 06:00 PM
RE: 35A5 tube substitution - by TV MAN - 03-16-2017, 11:37 PM
RE: 35A5 tube substitution - by wally73 - 03-17-2017, 07:12 AM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 8556 online users. [Complete List]
» 1 Member(s) | 8555 Guest(s)
