GE F53
Yes its a HP 432 A Power meter with a 478A termistor mount. When I worked for one of my last company they were throwing them away because they deprecated to 0. And replaced by HP 436 A's. They let the employees pick what they wanted before going to dumpster. Got a HP 141 Spectrum ANA that way to.. Both work Perfect..
Skip..
GE F53 - by vecher - 03-14-2017, 08:12 PM
RE: GE F53 - by morzh - 03-14-2017, 09:47 PM
RE: GE F53 - by Arran - 03-14-2017, 10:29 PM
RE: GE F53 - by morzh - 03-14-2017, 10:32 PM
RE: GE F53 - by vecher - 03-15-2017, 12:01 AM
RE: GE F53 - by OldRestorer - 03-15-2017, 08:02 AM
RE: GE F53 - by Mondial - 03-15-2017, 11:41 AM
RE: GE F53 - by vecher - 03-15-2017, 04:05 PM
RE: GE F53 - by vecher - 03-15-2017, 04:37 PM
RE: GE F53 - by Mondial - 03-15-2017, 04:41 PM
RE: GE F53 - by Mondial - 03-15-2017, 05:01 PM
RE: GE F53 - by vecher - 03-15-2017, 08:51 PM
RE: GE F53 - by Arran - 03-17-2017, 11:40 PM
RE: GE F53 - by vecher - 03-20-2017, 12:26 PM
RE: GE F53 - by Radioroslyn - 03-20-2017, 02:46 PM
RE: GE F53 - by vecher - 03-20-2017, 03:45 PM
RE: GE F53 - by Radioroslyn - 03-20-2017, 04:47 PM
RE: GE F53 - by vecher - 03-20-2017, 07:29 PM
RE: GE F53 - by vecher - 03-20-2017, 09:57 PM
RE: GE F53 - by Arran - 03-21-2017, 11:40 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6362 online users. [Complete List]
» 1 Member(s) | 6361 Guest(s)
