GE F53
Agreed.. My leads have .10 Ohm Resistance. And I measured .7 ohms so Real reading is about .6 Ohms.
I didn't like what the front of speaker looked like.. So that's what I was questioning..
Skip...
GE F53 - by vecher - 03-14-2017, 08:12 PM
RE: GE F53 - by morzh - 03-14-2017, 09:47 PM
RE: GE F53 - by Arran - 03-14-2017, 10:29 PM
RE: GE F53 - by morzh - 03-14-2017, 10:32 PM
RE: GE F53 - by vecher - 03-15-2017, 12:01 AM
RE: GE F53 - by OldRestorer - 03-15-2017, 08:02 AM
RE: GE F53 - by Mondial - 03-15-2017, 11:41 AM
RE: GE F53 - by vecher - 03-15-2017, 04:05 PM
RE: GE F53 - by vecher - 03-15-2017, 04:37 PM
RE: GE F53 - by Mondial - 03-15-2017, 04:41 PM
RE: GE F53 - by Mondial - 03-15-2017, 05:01 PM
RE: GE F53 - by vecher - 03-15-2017, 08:51 PM
RE: GE F53 - by Arran - 03-17-2017, 11:40 PM
RE: GE F53 - by vecher - 03-20-2017, 12:26 PM
RE: GE F53 - by Radioroslyn - 03-20-2017, 02:46 PM
RE: GE F53 - by vecher - 03-20-2017, 03:45 PM
RE: GE F53 - by Radioroslyn - 03-20-2017, 04:47 PM
RE: GE F53 - by vecher - 03-20-2017, 07:29 PM
RE: GE F53 - by vecher - 03-20-2017, 09:57 PM
RE: GE F53 - by Arran - 03-21-2017, 11:40 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
