38-60 Gonna be a lot of Trouble
Hi Terry,
It is just the primary side of the BC antenna xfrmer. The SW ant. xfrmer has no open coils. I guess I'll have to get some 38ga wire.
Really not sure how the coil form fastens to the underside of the chassis. If anyone has thoughts on how to remove the coil form, I'd appreciate their input. Otherwise, I'll keep looking...
Thanks Terry!
Jon
38-60 Gonna be a lot of Trouble - by PAradiogeek - 03-18-2017, 01:24 PM
RE: 38-60 Gonna be a lot of Trouble - by PAradiogeek - 03-19-2017, 11:56 AM
RE: 38-60 Gonna be a lot of Trouble - by morzh - 10-01-2017, 10:09 PM
RE: 38-60 Gonna be a lot of Trouble - by morzh - 10-17-2017, 10:48 PM
The speaker table error?
Philco 70 antenna lead
